Mattman928
#1 Posted : Tuesday, April 14, 2020 1:25:14 AM(UTC)
Mattman928
United States
I have a Bosch side by side model Bosch B22CS50SNS/01.
When we go to fill a glass of water from the dispenser on the front the first ounce of two flows nicely but then the flow slows to a trickle and a hammering sound comes from the area of the filter. I replaced the water inlet valve at the bottom of the fridge as well as the filter and all worked well for a couple of days, then it started again and has been making the noise ever since.
I wonder if this could be a voltage problem with the control board that is opening the water inlet valve. I don't know where the control board is, and also, what voltage or how the valve is regulated. Thoughts?
- Matt
