Hi
The auger motor can't turn the ice anymore. It runs for about 15 seconds, then stops and hums, even if I remove the tray of ice to remove the work. I notice a capacitor connected and adjacent to the auger motor. Your parts list call it a compressor run capacitor part number AP6010187. Does the compressor use this capacitor? If so, can I assume it isn't the problem with the auger since the compressor operates correctly?
