Rainer
#1 Posted : Tuesday, March 31, 2020 8:05:56 PM(UTC)
Rainer
United States
Hi after cleaning my range-top the rear 6" coil element stopped working. When I turned it on something arced; looking at it closely the terminal clip contacted the element and was spot welded to it.
I tried swapping a known good 6" element to that location, and it didn't heat either. I then tried the bad element in another location and it didn't heat.
My guess is that: the 6" element and the infinite switch are damaged? Possibly the terminal block.
The range is a GE Model JSS16OP1WH
I just want to confirm the specific parts; the infinite switch on my unit looks different from the listed one on the website.
Infinite switch AP2023855
6" surface element AP2634727
Terminal block kit AP2021472
Thanks!
Rainer
#2 Posted : Wednesday, April 8, 2020 1:45:53 PM(UTC)
Rainer
United States
Hi, ordered the 6" burner, infinite switch and terminal clip. Parts arrived in California in a day and a half. Turned off the stove breaker and replaced parts. 15 minutes later everything works perfectly.
THANKS!
GE Electric cooktop temperateure only has high or off ? (Oven Repair (including Ranges and Cooktops))
by emgconsulting 8/30/2014 10:15:28 AM(UTC)
Replacing GE Electric Cooktop (Oven Repair (including Ranges and Cooktops))
by jjefdwd 11/16/2009 12:00:17 PM(UTC)
Replace burner switch on GE electric cooktop (Oven Repair (including Ranges and Cooktops))
by mr2bob 1/27/2009 5:11:49 PM(UTC)
GE Electric Cooktop Surface Burner Replacement (Oven Repair (including Ranges and Cooktops))
by praskrish 7/16/2008 8:28:57 AM(UTC)
