canooten
#1 Posted : Friday, March 20, 2020 11:24:19 AM(UTC)
canooten
United States
Neither oven element will heat on this unit. The stovetop works fine and when you turn the oven on you get the normal feedback from the control board....you even get the usual click from the panel that normally coincides with the elements turning on, but neither element heats. Bake, broil, self-clean...nothing.
It seems odd that both elements would go out at the same time. Any other obvious things to check?
