Joined: 2/1/2020(UTC) Posts: 0 Location: MO - Missouri
My Samsung WF42H5000 washer will wash a load and then when it goes into rinse+spin the front display just powers off and then on and it restarts the rinse+spin cylce again. It just keeps doing this over and over again with no fault codes. It does this with or without clothes and it also does it weather low medium or high speed spin is selected. Should i replace the main board, the display board or the motor control board ?
Joined: 2/12/2020(UTC) Posts: 0 Location: Pennsylvania
Hello Elvir33, this sounds to me like there is a blockage and the washer isn't draining. What do you find when you unscrew the coin trap? Any grey sandy material? Any little pieces of grey metal? Is there any vertical movement in the stainless steel drum? The rinse+spin will repeat itself as it tries to drain. If you do find grey sandy material in the coin trap, this could be a sign of the spider corroding and breaking up. The spider is the three legged support at the rear of the drum. Or maybe there's a garment stuck in the drain pump.
