Hello, I have a Kenmore upright freezer(16 cu ft)model number 106.8211681, which (at times) will short cycle.I hear a click,it starts up, runs for a few seconds, clicks,then shuts down for a few seconds and will repeatedly do this for some time until it finally runs normally . The freezer works normally and very well roughly 95% of the time without the short cycling occuring,getting inside temps around -8 degrees(f)after its cooling cycle ends and will go back on around +5 degrees(f). I would appreciate any suggestions. I would also appreciate any directions where I could get a manual for this freezer. All I have is a parts manual. Edited by user Saturday, February 1, 2020 10:32:15 AM(UTC)
| Reason: additions
