jvasquez8
#1 Posted : Friday, January 10, 2020 5:29:25 PM(UTC)
jvasquez8
United States
Hello all,
First, thank you AppliancePartsPros.com for shipping a bunch of parts quickly. I wanted to share this so others can search and find an answer as well.
Model: Whirlpool WFW96HEAC0
Error: F08 E01
Symptoms: Washer would start to fill with water, then after 13 minutes, I would get the F08 E01 error on the machine. Looking at the water filling, only a trickle of water would pour into washer. There was a light buzzing noise when water was filling. I could not locate exactly which part the noise was coming from. Going into the diagnostic menu didn't reveal any additional errors. Additionally, when in diagnostic mode, the proper amount of water would fill the washer. Only when actually washing clothes does the washer error out.
Steps
1) Checked water pressure from hoses into washer. Water Pressure was strong.
2) Checked inlet valve screens. They were clean.
3) Inspected Washer Level Sensor Hose. No holes or damage. Replaced it. Still broken. Part Number: W11044559
4) Replaced Washer Level Sensor. Still broken. Part Number: W10448876
5) Replaced Washer Level Sensor Trap. Still broken. Part Number: WPW10260500
5) Replaced Water Inlet Valve. Still broken. Part Number: WPW10247306
6) Replaced Water Flow Meter. Still broken. Part Number: W10110225
7) Replaced Diverter Valve. FIXED!!!. Part Number: WPW10239942
Water now flows strongly. No more errors. Works great!
Hopefully this will help others if they have the same symptoms or issues.
