My dryer works fine on all cycles until the cycle reaches cooldown. The dryer keeps running, heat keeps cycling on, and timer doesn't move into cool down phase. Just acts like it is refusing to leave heat cycle. Will run forever cycling heat on and off. If I manually move the timer from the heat cycle to cool down cycle, the the timer finishes up correctly and shuts the dryer off in five minutes or so. The dryer just won't leave the heat cycle (both high heat cycle and easy care heat cycle). The timer moves forward in the heat cycle until it reaches the cool down transition and quits moving forward at that point. Any thoughts? Edited by user Sunday, January 5, 2020 3:27:27 PM(UTC)
| Reason: Not specified
