eng3
#1 Posted : Monday, December 30, 2019 5:27:03 PM(UTC)
eng3
I have a GE Profile side-by-side fridge (tps24pp).
The defrost drain is clogged. I managed to remove the ice around the drain. I tried pouring hot water down the drain, but the water does not flow at all. I tried poking something down the drain but it stops after only a cm or inch maybe. I'm not sure of the exact shape going down so I didn't want to push too hard.
I'd appreciate any suggestions.
