Hi - my Maytag Bravos washer won’t spin and is making a loud electronic type sound. Going to try to attach a video. We did unplug for several hours and plug back in and it’s still happening. The washer is currently full of clothes and water. I also tried removing lots of the clothes in case it was overloaded but that didn’t work either. It’s about 1.5 years old. I have a video of the noise but can’t figure out how to attach here if that’s possible.. Thanks!
Rank: Guest
Groups: Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
We had the same problem, the machine works great, unitkl it would not spin. no alarms light, nothing. The plastic hub wore away the metal "teeth" gears on the shaft.
