Joined: 11/3/2019(UTC) Posts: 0 Location: New Orleans
I replaced all of the following: driver shaft, bearings, washer hubs and then got error code F50 when running the diagnostics . I then replaced the motor RPS but no luck. Still getting F50 code, drum spins freely by hand. Any clue / suggestions before I call technician would be appreciated.
