Jcrosslin
#1 Posted : Wednesday, October 16, 2019 7:21:36 AM(UTC)
Jcrosslin
United States
I have a Frigidiare Affinity washer, front loader, and the lock control module went bad. We replaced the door lock and the washer would start the washing cycle. But know it will not complete the final spin. The clothes are clean but still soaking wet. I cleaned out the filter/drain but it still will not spin fast enough to remove water. We also, get an error when the washer gets to the spin cycle of "to much detergent". We have poured hot water down the dispenser as recommended on most fourms. The error listed is E47 but the door will lock and unlock.
Any suggestions?
