NO HOT WATER. NEED TO CHECK THE HEATING ELEMENTS FOR CONTINUITY AND SHORT CIRCUITS. HOW TO DO THIS? Also I cannot find parts for a hot water heater. Can someone help? Edited by user Saturday, September 7, 2019 9:52:08 AM(UTC)
| Reason: add a sentence
Originally Posted by: paul gesche  NEED TO CHECK THE HEATING ELEMENTS FOR CONTINUITY First of all, which model do you have? upd: sorry, totally missed it, since the name of your topic is reduced by forum settings. Still, my advice is still the same. Check that voltage is getting to the element. If you have an ohmmeter check it. The heating element should have about 9 - 11 ohms resistance. If you have the different number - that's the problem. We had about 15 ohms in our dying InSink-erator. Have a look at your model's manual if you still have troubles. - Patrick Edited by user Sunday, December 22, 2019 5:58:10 PM(UTC)
| Reason: updated with manual since I've missed the name of model
All the same advice will be. Apparently the problem was solved by itself ?
