My dryer (Frigidaire Model FAQE7073KWO) has lights that turn off and come back on by themselves. If you run it the dryer will turn and heat up for a few minutes and then turn off, but the lights stay on. I cannot reset it per the manual; push Start/Pause and Select at the same time and wait for a signal. There was no signal after more than 45 seconds. I cannot find a procedure in the manual for reading codes. Any help would be greatly appreciated.
