Hi, my dishwasher wont start, I just turned the knob slowly and it kicked on. I turned the knob and it went off, I cant get it to go on again. any ideas????
Open the control panel and check the wire harness to the timer. If there is nothing wrong then the problem very likely is a bad timer. - The part number for the timer is AP2039553Gene.
Originally Posted by: Gene  Open the control panel and check the wire harness to the timer. If there is nothing wrong then the problem very likely is a bad timer. - The part number for the timer is AP2039553Gene. Gene, the wiring look good. Most likely a bad timer. Thanks for your help. Jim
You are welcome, Jim. Keep us posted.
