I have a Magic Chef B 38HN 42TVW. When using the oven, I got an F4 error. I replaced the long oven sensor but a short time later started getting the F2 error, which I managed to cancel after unplugging the oven and rechecking the sensor installation.
Trying to use the oven immediately caused the F2 error to recur. I was still able to use the hob, but the problem now seems to be worsening as I have to use the door lock in order to keep the F2 sensor off.
Using a burner this morning caused the F2 alarm (even with the oven door locked) to keep appearing, and I have had to leave the stove unplugged for the time being.
Any suggestions gratefully received!
Steve
