My 26 years old Inglis Royal 100 direct drive washer model #IA48500 has couple of problems. It vibrates and shakes during the spin cycle. I think the vibration comes from the rear. The front walks about an inch to the right after the spin cycle is finished and the clothes are dry not drips or wet . I tried those rubber pads to insulate the washer feet but it make it even worse. The rear counter balance suspension spring seems fine. The washer works normal and no vibration during the wash and rinse cycles. It also make a loud noise when a cycle ends and starts into another. Over the years I have replaced the drive motor coupler and the agitator dog ears. Otherwise it is a great washer. Should I replace all the springs and the suspension pads or something else. I have uploaded a short youtube video to illustrate the problem. Thank you for your help! Edited by user Sunday, July 14, 2019 6:50:58 PM(UTC)
| Reason: Not specified
