bcwinn
#1 Posted : Sunday, June 9, 2019 9:39:00 AM(UTC)
bcwinn
United States
I have a Kenmore Elite that is not drying. I have tested all the fuses and replaces the relays for both the motor and the heat. Still nothing. I am getting no voltage coming to the two red wires of the heater relay... so i pulled them both out of the relay switch and spliced them together and everything works. I do not want to leave it like this - but it shows everything is working once i connect the two wires. Is this due to the control board not sending the proper 48v to the heat relay... which, I would assume, means my control board is baked?
Thanks!
B
