So, I am new to dishwashers. I have fixed freezers, refrigerators, and clothes dryers. My Kenmore is not draining at all. There is standing water in the bottom. I have gone through and cleaned the drains and then attempted to simply start the drain by pressing the cancel/drain button and closing the door, however nothing starts. I cannot hear the drain pump starting and no water flows into the garbage disposal.
So is this proof positive of a pump problem, or are there fuses that I can check? Something? I am continuing to search the forums to see if this has already been answered (I cannot imagine it has not been). Thanks for any help.
Did it show any error code?
