AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
LG DLE 5955 - keeps tripping upper limit thermostat
Morning all!
So we've had this LG dryer and washer for about 10 years. About 2 weeks ago the dryer stopped heating up. I took it apart, did the continuity tests on the thermostats and found that the upper limit therm had tripped. I replaced it and the replacement lasted a few hours. I then decided to look at the vent line. I did find a dead bird in there and thought that was it. Replaced the thermostat again and it too only lasted a few hours.
Last night I did the flow test that the dryer has built into it and it was fine.
I'm at a loss here. The dryer is electric BTW.
Thoughts??
Thanks for the help!
Dryer Repair
