kenworth48
#1 Posted : Tuesday, January 22, 2019 6:07:14 AM(UTC)
kenworth48
United States
I've had this range for about 10 years now and has been working great until a few days ago the oven temp got way to hot and burned my wife's cookies she was baking. She pushed bake, set temp to 350 and oven started at 175. I checked the temp in oven and it showed way above 500 degrees. I shut it off. I then let it cool down to normal.
That same day, I did another test, pushed bake, set temp to 350, then start. This time oven started at 100, and gradually reached 350, oven then beeped 5 times to let me know it had reached 350. However, the temp kept rising and went above 500 until I shut it off.I did this test several more times that day with the same results. My question is what parts do I need for this LG, Model # LRE30453SW/01. Thank you so much.
Macca
#2 Posted : Wednesday, January 23, 2019 4:21:11 AM(UTC)
Macca
United States
Problem is either the temperature sensor ( EBG61305801 ) or relay board ( 6871W1N012B ). Might be worth checking with LG, I seem to remember a recall because of an over temp issue.
LG Electric Range Overheating (Oven Repair (including Ranges and Cooktops))
by jenvee 1/25/2022 7:20:52 AM(UTC)
LG Electric Range KeyPads Working More Than One Burner (Oven Repair (including Ranges and Cooktops))
by gebo 4/23/2020 6:57:06 AM(UTC)
LG electric range temp control issues (Oven Repair (including Ranges and Cooktops))
by workaholic 10/20/2017 10:00:52 AM(UTC)
