Joined: 1/15/2019(UTC) Posts: 0 Location: Clarksville, md
We turned the breaker off and on to restart the bottom oven . That worked a couple of times. Now when I did that, it started then went to about 200-250 degrees and the shut itself off. Now I can’t get it to even start. TeLy need help with this mTter. The top is fine. I really don’t want to get a neevuyoven. ThAnk you ☺️
