I have a JBP66WY5 GE Range. The main 8" eye controller went out and the replacement part is no longer available and I was advised a new universal infinity control would work. Of course the wiring diagram did not match perfectly, but was close. Now the eye works but is on high no matter the setting. Did I miss wire something, or did I get a bad controller?
