Lemarac
#1 Posted : Wednesday, January 9, 2019 4:09:17 PM(UTC)
Lemarac
The dryer began to occasionally provide no heat while drying, and the cycle-end buzzer stopped going off - and sometime the dryer wouldn't stop at the end the cycle, it would continue spinning in cool down. We found that if we rotated the cycle-setting knob a few times, the heat would return.
I did a search here and got the first 2 recommended parts - a new dryer cycling thermostat and dryer thermal fuse. I replaced them and now the dryer doesn't heat at all. )-:
I dug out my multimeter and tested all of the fuses in the back, and they're all fine.
Could the element have gone out while the fuse still tests OK? I'm hesitant to pull that part off.
Alternatively, could it be an issue in the control panel and something with the settings knob?
How would I test for that?
Thanks in advance for any assistance.
Dan
