Hello - I have a Kenmore (model # 665.13122K702) QuietGuard Ultra washer that recently started giving me troubles. Currently the dishwasher just fills and then immediately drains no matter what cycle I start. The washer blades do not shoot out water at all during the cycle. I've ran the system diagnostics and all the codes come back with 8-2 and 8-3 (Cool water and cold water inlet codes) as well as a 3-3 which is a Thermistor/OWI failed calibration code.
I've never worked on a dishwasher before and based on these symptoms some forums have stated this could be the circulation pump as failed but the codes don't reflect that.
What do you guys think?
