AppliancePartsPros.com
Appliance Repair Help
Dishwasher Repair
Dishes dirty after Whirlpool/Kenmore Impeller replacement - incorrecct part?
I installed the impeller Drain & wash impeller kit Part Number: 675806. I still have debris on my dishes afterward. When I tightened the unit on install, it locked down the impeller so it would not rotate. I had to leave it slightly looser to allow it to turn. On inspection, the replacement part is different as it is flat rather than tapered/sloping. I contacted support but was told "The impeller for this Model did change at some point during productions Part# 675806 is a direct replacement for the original Part# 303539. This would be the reason the part would look a little different, however, it should be the functional equivalent. As long as the part is still working, that is what the manufacturer is looking for. Hopefully that helps!" I responded with my problem but did not receive a further reply. Am I on the right track here? Would a properly matched part allow this to be snugged down and still rotate? Thanks for any help!
The problem is the engine of the machine |
کلینیک مهنا
Dishwasher Repair
