Joined: 11/10/2018(UTC) Posts: 0  Location: West Virginia
I have a Jenn-Air duel fuel, model # JDS9860AAB range. I have replaced the touch pad and the control panel at the same time and now I have an error code of F1-E. The part # on the new control panel, ordered from AppliancePartsPros is WP74006363. Changed out to the original panel and then I get a F8 code which is a bad control panel. Switched it back again to new panel, again I have F1-E. Any help? Wrong control panel Or defective one?
switched
