HI, I have seen the E6 F2 error code on my Whirlpool double wall oven over the last month. I figured I would try to fix it myself so ordered the part control panel part https://www.partsips.com/panl-cntrl-part-wp8300429. Last night I went to try and remove the current board and noticed I am not able to pull out the panel far enough to remove the screws on the back as all the wires running into the control panel seem tied down with little room to pull out. Please see the two pics i have uploaded below. That's as far out as I can pull the panel away from the wall/oven. Do i try to unscrew the box without even being able to see the screw heads from these angles or try to cut wire harnesses and tie downs that i can kind of see farther back in the oven and hope there is more slack in the wires that are just tied down? https://drive.google.com...D4sPIVB/view?usp=sharinghttps://drive.google.com...VVc9W3X/view?usp=sharingany help is appreciated. hopefully the panel is the only part i need from what i've been reading! all the buttons have worked and beep when pressed, inside lights all good etc. just the display went out, came back, went out and eventually showed the E6 F2 code after about a month. Thanks.
