Installed new motor, tested to find that drum was faulty. Replaced drum/bearings. In start-up machine stuck in drain mode. Technician says to replace CONTROL PANEL & PRESSURE SWITCH. upon start-up the door is not locking and still in drain mode. HELP PLEASE MY WIFE HAS HAD ENOUGH OF LAUNDROMATS!
