DavidMark
#1 Posted : Thursday, October 11, 2018 6:25:40 AM(UTC)
DavidMark
Dryer Model: Whirlpool LE9200XWN0
Date Purchased: New in 1988
Problem: The Dry-Miser or Automatic Cycle doesn't work. The dryer heat works great and dries the clothes but it doesn't turn the dryer off when the clothes are dry. Instead it just keeps going and overdrys the cloths.
Notes: timer works. On all timed settings the timer will shut the dryer off and even reduce the heat at the end of the timed drying setting.
I don't know how the Dry-Miser feature works and I don't know which part to replace.
Any ideas would be appreciated.
Best regards,
David
Billy889
#2 Posted : Thursday, October 11, 2018 11:37:10 AM(UTC)
Billy889
Originally Posted by: ohm Go to Quoted Post
check the resistor on timer like in this post.https://www.appliancepartspros.c...imed-dry-diy1900209.html
Part number: 279872
Part number: 279872
Here is your wiring diagram.
Your looking for about 4050-4950 ohms!
+1
UserPostedImage
DavidMark
#3 Posted : Thursday, October 11, 2018 12:19:15 PM(UTC)
DavidMark
Hi Billy,
Thanks. I measured across that resistor and got infinity. I am going to replace that resistor and see what happens.
David
