lakez
#1 Posted : Thursday, September 20, 2018 11:09:16 PM(UTC)
lakez
Hi my dryer takes over 2 hours to dry clothe. I checked the high temperature limit switch which has continuity and as well the cycle limit switch which also has continuity.
The dryer turns on fine, and heat element works, it pumps out out humid air for 15-20 minutes then pumps out only mild warm air which is why the clothes are not been dried.
I suspect it is moisture sensor, but somehow I cannot find where it is located on this machine.
Any one can help?
Thanks.
vertspd
#2 Posted : Monday, September 24, 2018 5:12:38 PM(UTC)
vertspd
Dumb question....when was the last time you cleaned out the exhaust line?
lakez
#3 Posted : Thursday, September 27, 2018 9:44:01 PM(UTC)
lakez
Finally got time to check my dryer vent, yes you are absolutely correct, the dryer vent is almost fully plugged with lent and hair! Thanks so much for your reply, it solved my mystery dryer issue. Sometimes things are simpler than they seems.
Cheers
