How do I access the hidden bake element in the GE JKP30SM1SS (part WB44T10109) so that I can replace it?
The part finally arrived, and I figured this out. As you look at the front of the oven, remove the left side panel. At the bottom, remove the reflection pan door. This gives you enough access to wiggle the hidden bake element out and replace it.
