Symptoms: Two weeks ago, water below freezer door, temp 25 deg F, coil half frozen with ice. Thawed ice and it started working but not regulating temp well. After a few days, temp was well below 0 deg F.
At Present: Temp was about 25 Deg F, i think frozen food was keepinh it cold but food was starting to thaw. Ice was in the right corner near the temp control knob and on floor near drain, Coil had a heavy buildup of frost but not much solid ice. This time neither fan is blowing, compressor seems to be humming. I have photos but cannot find where to attach.
Regards, Tigerjim
