tiggers13
#1 Posted : Wednesday, January 18, 2017 1:31:44 PM(UTC)
tiggers13
We finally got the door off and replaced the glass. But now we are unable to get the door back on. I have watched many videos on u tube. The hinges on my door does NOT have that locking hinge to pull forward. please help
kay edman
#2 Posted : Tuesday, September 4, 2018 12:35:17 PM(UTC)
kay edman
You should see a small hole in the hinge when I is pulled back in the unlocked position. Stick nail in the hole to hold the hinge open. Remove it after you have inserted the hinges in the oven frame slots. No hole? The stick a bit in to ho!d the hinge open. Hope this helps.
