lordofthering
#1 Posted : Friday, August 31, 2018 8:10:54 PM(UTC)
lordofthering
I have below problem in my Refrigerator:
Compressor Running
Condenser Fan is Running
[COLOR="Red"]Evaporator Fan is not running. [/COLOR]
I tested Evaporator fan by disconnecting and connecting with 120V and fan is working fine.
What could be the issue ?. What else I can check ?
Freezer and Freeze both are warm and not getting cold at all. While I was at Evaporator Fan, I checked Evaporator coil and it was hardly cold (May be 50 Degree F)
lordofthering
#2 Posted : Friday, August 31, 2018 8:28:02 PM(UTC)
lordofthering
Originally Posted by: ohm Go to Quoted Post
Possible board under front kick plate bad, but is that available new has to be rebuilt. https://circuitboardmedi...st-control-board-repair/
Do you think it is in defrost mode and staying in Defrost mode ? If yes, how can I test it is indeed board and nothing else ?
How about refrigerator is low in Freon Gas ?
lordofthering
#3 Posted : Saturday, September 1, 2018 7:50:36 PM(UTC)
lordofthering
Looks like I have closed system issue. Leaking Freon. Not worth trying to fix it. Going to buy new one.
Thank you for everyone help here..This Forum is great.
