bnezzy
#1 Posted : Sunday, July 22, 2018 11:23:12 AM(UTC)
bnezzy
Hi all, I have a whirlpool gold side by side that stopped making ice. Through the help of the forum, I found the ice maker control module needed to be replaced. I ordered a new one, and replaced it. It's making ice again and all seems well.
My only concern is that the original module says 200 W-115V -60HZ. The new one was 185 W-115V - 60HZ. I've looked at other replacement pictures and I see others showing 185 W. Should I be concerned of the wattage difference, or is this just that the new part is drawing less wattage than the original? I want to make sure the new part isn't undersized in some way. Thanks!
ThatGuy
#2 Posted : Sunday, July 22, 2018 12:59:56 PM(UTC)
ThatGuy
Groups: Expert
United States
It's fine. It probably has a more efficient motor than the old one. I usually find it more cost effective to replace the whole IM.
bnezzy
#3 Posted : Sunday, July 22, 2018 2:43:09 PM(UTC)
bnezzy
Thanks for the quick response! I was hoping that was the case.
Guest (4)
