dhinla
#1 Posted : Wednesday, September 14, 2016 8:34:26 AM(UTC)
dhinla
Hi. I have a GE Profile [FONT=&quot]PFCS1PJYCSS. While it was under warranty, I had an issue where the fresh food section was freezing food. The repair person came out, said there had been a retrofit, and replaced an assembly and that fixed the problem. I have had the inverter replaced about a year ago.
Yesterday, my wife noticed that the fresh food section was freezing food again. Today I took a look at it and noticed the top gaskets were torn. I have ordered new ones from AppliancePartsPros to replace.
Wondering if there is a chance that this is what is causing the problem to have returned? Or if it is likely to be something more significant?
Thank you very much for any feedback you can offer.
[/FONT]
debczake
#2 Posted : Wednesday, July 18, 2018 6:40:20 AM(UTC)
debczake
Have you found a solution? I have had the control panel and temp sensors replaced last year on mine and it seemed to fix it then but now its back:mad:
