AustinLaBudda
#1 Posted : Tuesday, May 26, 2009 3:26:20 PM(UTC)
AustinLaBudda
Fridge all of a sudden would not get cold even with it set on coldest. Then the freezer was not freezing and basically turned into the fridge. The ice that had been there started melting. Took off back of freezer wall and the entire thing was frozen solid with ice. I melted the ice with a blow dryer and magically the fridge was cold again and the freezer was freezing again. However this only lasted a few days and it started doing the same old stuff. I would greatly appreciate the help as I do not have the money right now to pay someone to fix it.
woodchuckie
#2 Posted : Tuesday, May 26, 2009 3:45:08 PM(UTC)
woodchuckie
check defrost timer, defrost heater, defrost thermostat
Refrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com
If the heater and thermostat are ok it’ll be the control Part 801 on diagram 10-Replacement parts for GE ESS22XGMCWW | AppliancePartsPros.com
AustinLaBudda
#3 Posted : Tuesday, May 26, 2009 4:14:13 PM(UTC)
AustinLaBudda
when i locate them, how do i check to see if they work? i do not know much about fridge's but is it not the defrost heater? how can i check to see f that could be the problem?
woodchuckie
#4 Posted : Tuesday, May 26, 2009 4:45:18 PM(UTC)
woodchuckie
Follow the (how to) link in my previous post.
There may be some instructions in your user manual on how to "force" a defrost.
Guest (4)
