Maytag gas dryer igniter will not glow. Checked all fuses and ignites for continuity. All checked ok. Checked resistance on coils, both checked ok. Radiant flame sensor was ok for continuity also. Unsure what else to check to root cause the issue. Again dryer runs, but igniter will not glow or even get warm.
Forgot to mention that the sensor that tells you how dry the load is, did not show continuity when I checked it. Not sure that this would cause the igniter not to glow
When I put a conductor across the bars the dryness sensor does have continuity.
