rweltz
#1 Posted : Friday, June 15, 2018 4:41:50 AM(UTC)
rweltz
Hello,
I have a Samsung WF448AAP/XAA-0000 that still wont drain after I replaced the drain motor, control board, and the door latch. Not sure what to replace now. It still will not finish the cycle and drain. I guess my next step is to replace the front control panel. any other help would be greatly appreciated!! Thanks, Rich
rweltz
#2 Posted : Thursday, June 21, 2018 7:55:18 AM(UTC)
rweltz
can anyone help me out??? I got a te fault code in the terst mode, and it said it was the Thermister, so I replaced that also, and it still gives me the code. Any help??? Thanks,
rweltz
#3 Posted : Thursday, June 21, 2018 7:55:18 AM(UTC)
rweltz
can anyone help me out??? I got I te fault code in the terst mode, and it said it was the Thermister, so I replaced that also, and it still gives me the code. Any help??? Thanks,
Qkcam
#4 Posted : Thursday, June 21, 2018 3:51:16 PM(UTC)
Qkcam
i had a washer that was not draining before and i found out there was some stuff stuck in the drain line.. once i cleared it everything worked fine. if you haven't already check to make sure nothing is clogging or blocking the drain line.
