n.mcphee
#1 Posted : 7 years ago
n.mcphee
Dryer shut down after 10-15 min. Would not restart; error code “dr” appears. Replaced door switch, thermal limiter and safety thermostat per Appliance Pro videos. I thought “dr” referred to the door switch, but this did not correct the problem. Appliance Pro online tech stated there is no “dr” error code??? Currently the dryer green lights for normal dry cycle appear as usual; when start button is pushed green lights flash/beep rapidly and “dr” still appears in error code box??? There is no “dr” on the printed “dryer Tech data sheet” taped to inside of dryer. Can anyone offer help?
ThatGuy
#2 Posted : 7 years ago
ThatGuy
Groups: Expert
United States
Frigidaire Electric Dryer - All Lights Are Flashing (Dryer Repair)
by Guest 4 years ago
Frigidaire electric dryer stop advancing (Dryer Repair)
by blueking 11 years ago
Frigidaire Electric Dryer (Dryer Repair)
by Menotu 11 years ago
Frigidaire electric dryer, no heat (Dryer Repair)
by stevedill 12 years ago
Frigidaire electric dryer belt replacement (Dryer Repair)
by award 15 years ago
Frigidaire Electric Dryer - Blinking Lights (Dryer Repair)
by gin4sing 15 years ago
frigidaire electric dryer (Dryer Repair)
by GaydosBlessed 16 years ago
by cafero99 16 years ago
Need help replacing heating element coil in Frigidaire electric dryer (Dryer Repair)
by JeffJ 16 years ago
Frigidaire Electric Dryer Not Heating (Dryer Repair)
by tleelee 16 years ago
Frigidaire Electric dryer Hums and timer clicks (Dryer Repair)
by ButchL 16 years ago
by atlanta handyman 16 years ago
by outlaw 17 years ago
