jhamann101
#1 Posted : Friday, December 15, 2017 2:40:58 PM(UTC)
jhamann101
RF28HMEDBSR/AA: Turns off completely after one hour
Samsung
28 cu. ft. 4-Door French Door Refrigerator
I suspect this issue maybe be a result of several power surges. The fridge turns on and works perfectly for 3o minutes or so. The condenser turns on and the fridge begins to cool. The computer works without issue. Everything about the fridge seems functional for the first 30 minutes. The fridge then just completely shuts off. The lights inside the fridge turn off and it's like the fridge is not plugged in. I can restart the fridge and get it to run for another 30 minutes but it will then turn off again.
I'm handy and can change the board or various parts out but would like to have some idea of what’s going on before I start throwing time and money into this project.
Any thoughts on the problem here?
lsnow
#2 Posted : Saturday, December 30, 2017 4:09:45 PM(UTC)
lsnow
did you correct the problem with your fridge.I have a similar problem .My samsung fridge just completly shut down with no warnings and it is only 3 yrs old
Cliprship
#3 Posted : Sunday, May 27, 2018 8:04:48 AM(UTC)
Cliprship
Did either of you figure out what was going on?
I have a similar issue. Freezer works fine - refrigerator light stays on for 30 minutes or so and then when I open it, the light is off - like it has lost power. It's cool in the refrigerator section but the temperature will start to increase. My ice maker / water dispenser isn't working at any point.
Thanks!
