ridiculouslyfrustrated
#1 Posted : Saturday, May 19, 2018 2:00:32 PM(UTC)
[LIST=1]
  • The panel has no lights but pressing the cancel/drain button drains the dishwasher and eventually the pump stops running.
  • Pressing start goes right in to a cycle with the Pots/Pans, Drying, Hi-Temp Rinse lights lit. Leaving it running will result in the cancel light and 4/6 delay lights coming on.
  • Canceling drains but never resets the unit and it goes right back to starting mid-way through a pots/pans cycle.
    [/LIST]
    Powered off for minutes without change.
    Left it running through a complete cycle as according to a different site the unit can get "confused" when it's lost power and has to complete the cycle even if it takes 3-4 hours. It ran for 4 hours and ended with just the Clean light lit but panel did not respond, pressing cancel drained and put us back to starting mid-way through a pots/pans cycle.
    Assume it's not something inexpensive like a thermal fuse but thought I'd ask if anyone had seen these symptoms before buying a new control board.
  • Sponsor
    #2 Posted : Friday, June 29, 2018 7:55:54 PM(UTC)
    Ordered a new control panel and that resolved the problems, dishwasher ran through a complete cycle without error.
