Mar-Gun
#1 Posted : Saturday, May 12, 2018 10:33:26 AM(UTC)
Mar-Gun
Groups ready for retrieval: Registered
I just moved my Maytag Dryer from a boat to my Shop. The Shop has been re wired and has never had a Dryer. I didn't check how the Dryer was working just before the move. Any Dryer that has been on a boat has had a ruff life. Anyway when I go to turn it on all I get is the LED lights running threw a continuous cycle. 44-22-11-44-22-11 .... and all the other lights going threw test cycle. Obviously this is to tell me something is wrong, however I don't know the answer. Reading the manual I see that it can be 230 or 208 wired. This I have not checked this yet. A wire or Plug may be loose or the brain board is just fried. Idea's ????
Mar-Gun
#2 Posted : Monday, May 14, 2018 2:12:25 PM(UTC)
Mar-Gun
Well I have confirmed that it is a 240 Volt Dryer running on 208. However leaving it plugged in for a couple of days has calmed it down and it is now running. No Heat, but otherwise running. I'll check into what it takes to convert it to 208 but I expect it will be more than what its worth.
