I'm struggling with my dishwasher repair. The triage: - the tub will fill - it will drain the tub - the spray arms move freely. They are clean and free of debris. But the dishes in either the upper rack or lower rack are not anything more than "damp". - I dissassembled the pump and motor. The filter was badly damaged. I ordered a replacement filter and installed it, but the symptoms persisted. Otherwise, the pump looked clean and free of debris. - the heater element works. - but the dishes don't get clean at all. - otherwise it makes the usual noises during the cycle.
It is a Kitchen Aid, model KDTM354DSS4 that is about 18 months old.
Any ideas? Any other information needed to assist with the diagnosis and repair options?
I purchased a new wash pump and motor, but the problem remains. What's the next move? Fill it with firecrackers and blow it up in the back yard?
mine is having exact same issue, did you end up finding how to fix it?
