buddha61
#1 Posted : Wednesday, November 15, 2017 5:18:32 PM(UTC)
buddha61
Hi all, first post here. Let me start with the basics. I have lived around Chicago for the last 6 years, and just recently moved back home to Ohio with my mom. She told me a while ago that the oven wouldn't work, and thought that it might be a fuse. I have looked briefly (didn't want to take it apart, as the stove top still works, though one or two of the ignitors might be toast, as it requires manual lighting). I am not sure how old it is, but probably close to 10 years. It is a Whirlpool Accubake, model SF387LEGW3.
What I do know. The oven light doesn't light up (not sure if burnt out or part of the problems). The oven won't work, nor does trying to push any button on the control panel. Some times the control board is completely blank, sometimes it appears on, showing something like 8s all the way across. I am unsure if the problem lies in the control board, a fuse, both, or something else. Looking for a little guidance as to what I should check first. I have briefly looked at the pamphlet that was in the back of the oven, that shows wiring diagrams, but no clear determination where the fuses are, unless bk is them.
Any assistance you could give would be immensely helpful. I will include a quick picture, though hard to see, of what the control panel looks like, as the flash light washes out most of what you can actually see (you can kind of see in the time area, where the greenish numbers should be).
buddha61 attached the following image(s):
buddha61
#2 Posted : Tuesday, April 17, 2018 5:18:43 AM(UTC)
buddha61
Well, it is a few months later, and I finally took part of the back of the oven off, took off the control panel, and found this spot near the top left of the 'glass' area that would be part of the forward display. It also appears some of the soldering is browned. Looking at it, I assume that it has shorted/burned out some part of the control panel. I assume replacing it could/should fix the oven?
