DebMcKay
#1 Posted : Friday, July 22, 2016 5:06:14 PM(UTC)
DebMcKay
The other day, went to close the freezer drawer on my Samsung French Door Model RS217ACRS, and two parts came off. One part is squarish (rectangular) and has embossed on the front of it "Space Compact Ice Maker", I think the part number is DA63-03613A, located on the inside of the cover, and then a plastic piece that I have seen the part for on the parts list, but it does not look broken. Is this going to effect how my ice maker works?
Jakofall
#2 Posted : Wednesday, April 11, 2018 9:06:22 PM(UTC)
Jakofall
For future readers: The square part is probably the soft, rubbery block that holds the sensor. Without it, the sensor will dangle and could easily be torn off. If that happens, the refrigerator will fail its self-test after a power-outage or being unplugged and plugged back in.
If the sensor wires are broken, you can fool the self-test by briefly touching the wires together, but you run the risk of the system crashing if you're not around to short those wires.
Samsung french door bottom freezer loud buzzing and water leak (Refrigerator & Freezer Repair)
by surgeslayer2 10/19/2023 3:33:56 AM(UTC)
Samsung french door frig (Refrigerator & Freezer Repair)
by Guest 6/16/2022 1:01:18 PM(UTC)
Samsung French Door Refrigerator freezer not cold enough (Refrigerator & Freezer Repair)
by Sh@wn 1/5/2022 6:50:52 PM(UTC)
Samsung french door refrigerator water leak (Refrigerator & Freezer Repair)
by rodey01 12/22/2021 5:20:31 AM(UTC)
Samsung French Door Refrigerator RF28R6301SR/AA Freezer getting too Cold (Refrigerator & Freezer Repair)
by BlueCrabs 12/6/2021 4:29:26 AM(UTC)
Samsung french door freezer won't hit set point (Refrigerator & Freezer Repair)
by jmpage2 9/3/2021 3:09:38 AM(UTC)
Samsung French Door Freezer cooling (Refrigerator & Freezer Repair)
by edelatl 7/5/2020 6:49:24 AM(UTC)
Samsung French door refrigerator ice maker (Refrigerator & Freezer Repair)
by katiebell 5/3/2013 9:41:52 AM(UTC)
Samsung French Door - everything is frozen (Refrigerator & Freezer Repair)
by mdelli02 11/29/2012 2:50:45 PM(UTC)
