2 Pages<12
Bill1
#11 Posted : Tuesday, April 10, 2018 6:51:13 PM(UTC)
Bill1
smckech1972 analysis lead me to my solution.
I have a Maytag QuietSeries 300, MDB8601AWW10689934l, with the tub being a single mold unit with the float located on the front right, leaking at the float assembly under the tub.
The float extends through the tub resting on the float switch.
An Ohms check of float switch was positive (good)
However, drips of water (often a small stream of water) was leaking at the float\switch.
Steps taken:
Removed float and cleaned gunk under the "cap"
Re-installed float
Ran rise cycle - okay no leaking
Ran wash cycle with encapsulated dishsoap product
Water on floor. Float leaking
Filled liquid "jet dry" reservoir with white vinegar and poured 1 cup in tub
Started dishwasher on Auto Clean High Temp
Drip, drip, drip
Opend door to observe soap suds in tub
Let cycle complete
Next I poured a cup of liquid CLR into the tub followed with 3 cups of hot tap water
Started dishwasher on Heavy Wash, Tough Scrub, High Temp cycle
After tub filled with water
Drip, drip
Opened door, lots of suds
Closed door, cycle resumed
Time goes on
Drips slowed
Opened door less suds observed
Time goes on
Drips slowed
Drip stopped
Next I poured a second cup of CLR into the tub followed with 3 cups of hot tap water
Drip, drip
Let cycle continue
Opened door, suds
Time goes on
Drips slowed
Opened door, less suds
Time goes on
Drips stopped
Not comfortable
Poured what was left of CLR
Drip, drip
Opened door, suds
Time goes on
Drips slowed
Let cycle complete
Poured 1 cup of white vinegar in tub with 3 cups of hot tap water
No Drip
Opened door, no suds
Let cycle complete
No Drip
Let cycle complete
Really did not want to disassemble the dishwasher
Many cycles of cleaning, saved $300 on a new dishwasher
ronakshah2000
#12 Posted : Thursday, April 12, 2018 6:45:52 AM(UTC)
ronakshah2000
Just a followup - my fix solved my problem. About 1-2 years later I replaced with a kitchenaid as the JennAir just didn't clean well (and never really had). Love the KitchenAid.
Guest (5)
2 Pages<12
