Whirlpool Duet Dryer W10136508 A
I have a Whirlpool Duet Dryer (W10136508 A) with a busted hold to start button, which we were using by just pushing in the microswitch with an old stylus, but now the switch broke off. I'd like to attempt replacing the microswitch. But I can't figure out exactly how to remove the panel and circuit board assembly.
The videos on the net about WP Duet don't show my particular model (pictures below). Can someone point to any videos or any instructions on how to remove the panel?
Thanks in advance, Shash
Sorry - I had the model number wrong. The actual model number is W10031420 Rev A. I have managed to remove the UIF panel. Does anybody have a link to the service manuals for this dryer? What bit do I need to use to remove the screws? I see that this kit might replace mine if I can't remove it.
