sendto
#1 Posted : Friday, March 16, 2018 8:49:42 AM(UTC)
sendto
Trying to replace the oven door hinges. All the YouTube videos show lockouts over the hinges. Then the door is very easy to lift off. This door will not lift off. Please help.
ThatGuy
#2 Posted : Friday, March 16, 2018 3:06:05 PM(UTC)
ThatGuy
Groups: Expert
United States
Do you have your owners manual? If you do go to page 12, it tells you how to remove the door.
Whirlpool Use and Care Guide - 98016353-012 - YouserGuide
If you don't have the "hinge pins" I've used two small screwdrivers or you could use two nails the right size.
sendto
#3 Posted : Friday, March 16, 2018 4:00:53 PM(UTC)
sendto
Thank you Sir. I will look at in the morning.
You are a blessing
